Quicktime Downconvertion
jpirizarry
on Jan 16, 2007 at 6:58:07 pm
I already bothered you with this issue but I still haven't been able to fix it. I have a 720p 58.97 DVCPRO HD project, and I'm trying to burn a SD version using compressor and DVD studio pro. The DVD looks very soft and the graphics lack quality. I've try different techniques, but I still haven't found a solution. Is there a format I should downconvert to? Does this has anything to do with the frame rate? Which is the best way to do this?
Shane Ross
Re: Quicktime Downconvertion
on Jan 18, 2007 at 10:20:40 am
Don't downconvert before you burn the DVD. Try first exporting a Quicktime Movie (uncheck SELF CONTAINED and you will export a reference file...much smaller) and then take that into Compressor and choose one of the High Quality DVD encodes, making sure to check the 16:9 letterboxed option. Then burn the DVD. I have had great looking DVDs come out that way. DVCPRO HD footage.
Shane
Littlefrog Post
http://www.lfhd.net
