Pal project won't leave!
Bob Buruchian
on Jan 9, 2007 at 10:59:21 pm
We did a pal project a few weeks ago, now when we are back to our normal DVC Pro 100 (NTSC) project, FCP (5.1.2) keeps switching our Kona 2 (3.3) to 108025i PAL upon capture. The source material is the same it's always been in this room NTSC. If we switch our easy set up to another aja K2 setting like 108029.97 8 bit it captures fine but when we go back to 1080 29.97DVCproHD it comes up with an error that says dropped frames and it switches the Kona 2 to Pal ??? After dropping prefs in FCP, reinstalling Kona 2 and IO, checking video sources, machines, routs, etc. we're told from AJA to reinstall FCP. I'm hoping that someone on this forum has an easier fix
Bob
Bart Harrison
Re: Pal project won't leave!
on Jan 10, 2007 at 12:16:38 am
Bob,
Do you have blackburst hooked up in that room ?
Bart
Bart Harrison
MPA - The HD Suite
America's VAR
TurnKey Editing Systems, Storage Area Networks
HD Consulting, Production & Post, Exhibition & Distribution
http://www.hdsuite.com
954-894-1221
Bob Buruchian
on Jan 10, 2007 at 4:23:53 pm
Hi Bart,
Yes we have blackburst, none of the wiring or sources in the room have changed.
It looks like we need to reinstall FCP
Bob
