importing dvcpro hd from m10u to lhe audio/video settings?
cadobee
on Dec 15, 2006 at 7:54:05 pm
i cant figure out the settings to import dvcprohd from my m10u deck the my new lhe card. i have final cut 5.1.2 on my g5 running tiger. also, ive heard alot about audio being difficult? i've got a matchbox, and everything is run right though.
thanks
Brian McCartney
Re: importing dvcpro hd from m10u to lhe audio/video settings?
on Dec 15, 2006 at 8:39:32 pm
I have an M25U deck but I think the process is the same. Make sure that the Kona control app has the component analog video setting checked for input and also the make sure analog audio is checked. In FCP create an easy setup based off the DVCProHD 1080i settings and change the deck control to Apple Firewire. You may need to change the deck control offset (my deck uses a 4 frame offset). Not sure if I am leaving anything out but The AJA website actually has a decent white paper on goign from HDV to DVCProHD, that should give you a very good idea of how it all works.
cadobee
on Dec 15, 2006 at 9:00:42 pm
well, i sort of figured it out. i can use the deck as an uncontrollable device, but i though i woulf be able to control the deck with final cut? also, im still getting no audio, i'll test the output of my matchbox.
JeremyG
on Dec 15, 2006 at 9:13:21 pm
Use firewire for deck control.
cadobee
on Dec 15, 2006 at 9:18:38 pm
i tried that, and it didnt work.
JeremyG
on Dec 15, 2006 at 9:24:30 pm
HDV firewire?
cadobee
on Dec 15, 2006 at 9:28:05 pm
ya, when i hit log and capture, it give me an error message...
to capture hdv soure material both the capture and device control presents must be configured for hdv...
JeremyG
on Dec 15, 2006 at 9:41:43 pm
What you need to do is select the 1080i DVCPRo HD capture preset then go into the log and capture, window and change your capture device to HDV firewire. Or you can make your own preset with all the required parameters.
See here:
http://www.aja.com/pdf/support/AJA_whitepaper_HDV.pdf
Jeremy
cadobee
on Dec 15, 2006 at 9:55:12 pm
i did easy setup dvcprohd, the went to capture window, capute settings tab, but there is no hdv anything. there is sdv, but that doesmt work
Brian McCartney
on Dec 16, 2006 at 1:15:02 am
You will need to set the deck's firewire port to DV downconvert. The device control in FCP in log and capture will not work if the firewire port on the deck is set to HDV.
cadobee
on Dec 16, 2006 at 9:44:31 pm
i just remembered that last night (must have been in my dreams)
ill try that
walter biscardi
on Dec 16, 2006 at 11:24:31 pm
[JeremyG] "What you need to do is select the 1080i DVCPRo HD capture preset then go into the log and capture, window and change your capture device to HDV firewire."
This doesn't work with FCP 5.1.2 and not sure if it works with any FCP version. If FCP sees the HDV signal via Firewire, it says that all settings must be HDV to capture. The only way to control the deck is to ensure that the Firewire is set to downconvert to DV and then use DV for Deck control.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Food Network's "Good Eats"
HD Editorial for "Assignment Earth"
"I reject your reality and substitute my own!" - Adam Savage, Mythbusters
JeremyG
on Dec 19, 2006 at 4:28:02 pm
Yep, thanks for pointing that out, Walter.
Jeremy
