KONA, FCP and audio monitoring issues?
jamie
on Dec 13, 2006 at 12:42:06 am
hey team,
i just assembled my new edit suite today. My issue is, I cannot get the RCA audio monitoring outputs on the K box to output any audio. I can get audio from my timeline to my deck via the SDI connections, but wont come directly out of the K box. I am viewing component out of the k box to my monitor. is this an FCP issue or a kona problem?
My set up:
G5 quad 3.0 intels
kona 3 w/K Box
ciprico 4210
FCP 5.1
any thoughts?
thanks,
j
walter biscardi
Re: KONA, FCP and audio monitoring issues?
on Dec 13, 2006 at 1:25:38 am
If you have audio via SDI then you should have it via RCA. All outputs are hot.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Food Network's "Good Eats"
HD Editorial for "Assignment Earth"
"I reject your reality and substitute my own!" - Adam Savage, Mythbusters
jamie
on Dec 13, 2006 at 1:41:27 am
this is where my confusion sets in... i know im supposed to have audio coming through, however, its not. i have plugged the rca's in to multiple devices to test for sound. nothing.
thanks,
j
ken hon
on Dec 13, 2006 at 2:52:47 am
Aloha Jamie,
Ok this is going to sound dumb, but try taking the DVI cable that is used to connect the K-Box to the card and reverse it (attach the end that is now on the computer to the K-Box and vice versa). I recall having the same issue and this fixed it.
Ken
Jamie
on Dec 13, 2006 at 2:16:39 pm
tried that, no luck.
thanks for the advice though, guess i will call aja directly.
thanks again,
j
