choosing Kona card for multiple audio streams
Anshul Doshi
on Dec 8, 2006 at 9:34:30 pm
Dear All
Currently I am setting up a FCP setup for a client to edit a feature film.
I have a client who is hooting on HDCAM and will have Beta rushes also of a feature film
I am deciding the correct caputre card.
Perfect solution if I had all money is Kona3 with the breakout box
The main consideration in the selection is the following:
a) He needs to capture 4 streams of audio and monitor 4 or more streams of audio
Is this possible with the Kona LH with a breakout box?
Thanks and Regards
Anshul Doshi
walter biscardi
Re: choosing Kona card for multiple audio streams
on Dec 8, 2006 at 9:58:49 pm
Yes, via SDI the Kona LH can capture 8 channels of audio. 2 channels of Analog Audio.
If you're setting up a new Mac Pro machine or a G5 Quad, you will require the Kona LHe model.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Food Network's "Good Eats"
HD Editorial for "Assignment Earth"
"I reject your reality and substitute my own!" - Adam Savage, Mythbusters
Anshul Doshi
on Dec 8, 2006 at 10:01:40 pm
thanks walter
actually i need to have 4 channels on the output to an audio mixer
is this possible through any audio de-embedder as on output i need 4 seperate channels of audio to go to the mixer.
thanks
anshul
walter biscardi
on Dec 8, 2006 at 10:06:14 pm
According to the specs it will output 2 channels of analog, but I know it can output 8 channels via SDI. Call AJA and they'll definitely tell you how to set it up for the 4 channel output you need.
But yes, this can be set up. We output 4 channels all the time from our Kona 3 for mastering via SDI direct to the decks.
Anshul Doshi
on Dec 8, 2006 at 10:10:34 pm
do you have a number for kona that you can give me where we will get support
sorry to hassle
thanks
anshul
walter biscardi
on Dec 8, 2006 at 10:25:30 pm
aja.com
