Zelin's storage recommendation for FCP
Paul Holzman
on Dec 6, 2006 at 6:36:47 am
A while back Bob Zelin recommended the following drive set up for a low cost Raid 0 FCP system: Sonnet E4P, Fusion 500 and 5 Hitachi 500 Gig SATA drives. I'm now in need of storage for a G5 PCIx system that will have both FCP and M100HD on it with a Kona LH. My question is whether this is still recommended? Or has something like CalDigit (which MacGuru is pushing) replaced it. Or are they essentially equivalent. I mainly do SD--uncompressed or DVCPro 50. I'm just starting to do productions with DVC Pro 100. I'd like to be able to edit with 5 or 6 layers in RT.
Paul
Shane Ross
Re: Zelin's storage recommendation for FCP
on Dec 6, 2006 at 12:04:34 pm
Both are highly recommended. Both work well.
Shane
Littlefrog Post
http://www.lfhd.net
Bob Zelin
on Dec 6, 2006 at 1:25:40 pm
I agree - for standard def, both the Sonnet solution and the Cal Digit are teriffic, and very reliable. You can get both from Maxxdigital in california. The CalDigit is the only 5 drive solution that can do uncompressed HD, however.
Bob Zelin
ps - enough with the M100
Paul Holzman
on Dec 6, 2006 at 2:31:44 pm
Thanks Shane and Bob....I'm assuming Caldigit can do the HD uncompressed by striping 10 drives together? And Sonnet can't?
Paul
PS, Bob, can we take the "ps enough with M100" offline? I'm curious.
Bob Zelin
on Dec 7, 2006 at 12:21:21 am
this is incorrect information. Both the Sonnet and Cal Digit will do uncompressed HD with 10 drives. But the Cal Digit will do uncompressed HD with 5 drives (the Sonnet will not). With 10 drives, you will get over 450mb/sec with both systems - faster than an Apple XServe RAID.
Bob Zelin
ps - as for the smart ass comments - if I can't make them, why should I even be alive ?
Paul Holzman
on Dec 7, 2006 at 4:09:30 am
[Bob Zelin] "ps - as for the smart ass comments - if I can't make them, why should I even be alive ?"
I completely agree. Much of your essense would be missing. But I think you miscontrued my query (perhaps because so many people misconstrue your comments). I merely wanted to ask you a question about M100 without cluttering up the Kona forum.
Paul
