Kona LH Audio Echo
Martin Phillips
Kona LH Audio Echo
on Nov 28, 2006 at 5:35:29 pm
Hi - have searched forum but not come up with a conclusive answer on this one. Have just installed Kona LH - all works fine, apart from whenever I stop the video playback in the timeline, I get a 1sec echo. Sounds like something is not quite set right, but I can't seem to get to the bottom of this. Any ideas or solutions?
Thanks, Martin.
G5 Dual 2G, Kona Lh + Breakout box
Jerry Alto
Re: Kona LH Audio Echo
on Nov 28, 2006 at 5:41:45 pm
Martin- You may be hearing both your production speakers AND your computer speakers. Check your speaker settings in your system preferences and production preferences.
Jerry
G5 Dual 3GB Ram
FCP5 Studio
External 1 TB SATA Raid 0
Kona LH, Second system w AJA ioLA
Sony Z-1
Martin Phillips
on Nov 28, 2006 at 5:49:08 pm
Thanks Jerry,
I have Kona selected in my System Prefs, have tried the others but still does the same ......
Martin.
Martin Phillips
on Nov 28, 2006 at 7:30:00 pm
Just heard back from AJA - who say I need a G5 firmware update. The only one I can find is for the single 1.6 processor 5.5f1. Don't know whether I should put this on?
Martin Phillips
on Nov 28, 2006 at 10:30:38 pm
Well, I've got this sorted now. So just for info I downloaded the 5.1.4 firmware update which is at http://www.apple.com/support/downloads/powermacg5firmwareupdate.html
All working fine.
Martin.
Jerry Alto
on Nov 29, 2006 at 1:03:27 am
Martin- Sounds like the folks at AJA pointed you in the right direction. Tech support at AJA is THE BEST.
Jerry
G5 Dual 3GB Ram
FCP5 Studio
Sony Z-1
