Hiss on Audio Output of Kona 2
Isoparm
on Nov 21, 2006 at 6:11:21 pm
Hello,
I've only used the video output of my Kona 2 card until now. Yesterday I tried to monitor the audio output of my Kona 2 card and discovered that all I hear is a loud hiss.
I've tried 2 driver versions (1.x & 3.3), but that didn't help. I've tried both Apple's Soundtrack Pro & Final Cut Pro (5.1) and AJA's TV output program, but got the hiss on all three.
I was running the Kona 2 XLR cable into a Mackie mixer and also tried a Digidesign MBOX.
Anybody have any idea on why I'm getting a hiss, and how I might be able to correct this?
Timecode Multimedia
Re: Hiss on Audio Output of Kona 2
on Nov 21, 2006 at 6:29:03 pm
We experienced an issue like that when we used the audio output for the first time.
For a long while we only used the video out just like you.
The trick is to go to the Mac's System Preferences - Sound and adjust all audio outputs
to 64. (adjust the audio level - then move the mouse away from it - then place on the
level marker again- a tip tool type window will pop up and give you the level number)
Hope this helps...
Stuart Ferreyra
Timecode Multimedia
President
Santa Monica, CA 90025
http://www.timecodemultimedia.com
Isoparm
on Nov 21, 2006 at 9:59:48 pm
Thanks for the advice. Turns out the issue is that the Kona's connections are AES and not analog. I was trying to monitor via an analog source so that was my issue.
Timecode Multimedia
on Nov 22, 2006 at 4:41:48 am
Yeah, that would be a problem.
Use the RCA outputs for monitor.
Stuart Ferreyra
Timecode Multimedia
President
