Installing Uncompressed 10 bit codecs for After Effects 7
Simon Choi
on Nov 21, 2006 at 5:48:38 pm
Hello,
I work in a department which has currently upgraded our department to After Effects 7. The G5 workstation have a mixture of Aja Kona and Blackmagic cards. There is a fair degree of file sharing Qts, which are then imported into Final Cut Pro and layed off to Digi beta.
However i would like to know how to renderout Quicktimes to the generic Uncompressed 10 bit to avoid conflicts. This is usually featured in After Effects 6.5, but is no longer available as option in either After Effect 6.5 and 7 since we upgraded.
In the After Effects Interface
Compostion - Make movie
mactrix
Re: Installing Uncompressed 10 bit codecs for After Effects 7
on Nov 23, 2006 at 4:37:44 pm
The uncompressed 8 and 10 bit codec ist installed by Final Cut Pro.
You can also download BMD and AJA drivers to install the codec ...
