Kona LH audio dropout
Shane Ross
on Nov 10, 2006 at 6:13:35 am
I just received a Kona LH and dropped it into my Dual 2Ghz G5 (PCI-X)...well, OK, I carefully installed it into my G5. Then I connected HD SDI out to my HD monitor...and it looks great. But when I take the XLR outputs and connect them to the balanced IN ports on my Tascam FW-1082 mixer, and play the timeline, I will get occasional and regular dropouts in audio. The VU meters stay steady, it only happens on the mixer end. I connect the speaker out of the G5 to the mixer and the audio sounds fine...no dropouts.
Anyone experience this...and solve it?
Shane
Littlefrog Post
http://www.lfhd.net
JeremyG
Re: Kona LH audio dropout
on Nov 10, 2006 at 10:44:55 pm
SO it sounds like it's a problem with your tascam or your setup.
I just looked at the Tascam and it appears those XLR inputs are mic level. Could that be your problem? if you hook up your KOna card to anything else (like a deck), do you still get the same dropouts?
Are you sure you have hooked up the analog outputs and not the digital?
Most recent drivers/firmware from the AJA site?
Jeremy
Shane Ross
on Nov 12, 2006 at 3:16:49 am
I'll look again. I am currently working 12 hours 6 days a week so I have little time to devote to my home system. But those are all good things to check out.
Shane
Littlefrog Post
http://www.lfhd.net
JeremyG
on Nov 12, 2006 at 4:18:41 pm
Good luck, Shane. I know that schedule you are on very well.
Jeremy
Shane Ross
on Nov 13, 2006 at 8:29:23 am
Hmmm...they are the ANALOG OUTs...so.
I will have to look into this later.
Shane
Littlefrog Post
http://www.lfhd.net
