How to capture a computer screen, just like Apple.com? HELP!!
Philippe C
on Nov 8, 2006 at 4:56:41 pm
I want to digitize the video signal out of a PC through the board (I have a Kona 3) into a HD format, like DVCPRO HD 720p30.
What do I need to make it work?
Does any of you have done it before?
see example:
http://www.apple.com/macosx/leopard/timemachine.html
The only solution I found were software based.
Thanks for your help!!
Timecode Multimedia
Re: How to capture a computer screen, just like Apple.com? HELP!!
on Nov 10, 2006 at 4:11:43 am
Why don't you get a DVI to Video to SDI converter box (or boxes), connect it to
a separate Mac with the Kona and capture it?
Sounds expensive to me; unless there are other solutions.
Stuart Ferreyra
Timecode Multimedia
President
Santa Monica, CA 90025
http://www.timecodemultimedia.com
Tycho Sj
on Nov 29, 2006 at 9:41:47 am
I believe an easier way would be to use Snapz Pro ( http://www.ambrosiasw.com/utilities/snapzprox/ ) to record the part of the screen you want to record into a QuickTime file. Later you can convert that file into any format. I'm quite sure that's the way Apple does it.
Tycho Sj
