Larger Timecode Viewer in Final Cut?
greg jones
on Nov 3, 2006 at 4:00:59 pm
Currently the only way to easily view the sequence timecode is by the small numbers to the left of the sequence. Does anyone know of a plug-in out there that lets you adjust the size or create a timecode window to view similar to avid. I know there is a timecode reader and generator plug-in but that only shows up over the video. I'd like a separate window.
Greg Jones
D7,Inc.
Orlando,Fl.
chrispy
Re: Larger Timecode Viewer in Final Cut?
on Nov 3, 2006 at 4:22:32 pm
This is what you need :
http://www.digital-heaven.co.uk/bigtime/
-chrispy
RonnyRon
on Nov 5, 2006 at 4:31:59 am
Its not a plug-in but, If you can, get a Mackie Control Surface. The timecode is displayed on nice bright red LED's, and stays in sync with FCP via USB to MIDI interface. In addition to flying faders and RT mixing, you also gain handy transport controls and jog wheel that works seamlessly with FCP, Soundtrack, and Logic Pro.
http://www.mackie.com/products/mcu/index.html
Ron
RIOT Productions
G5, Kona LH, Atto UL4D, FCP5, QT 7.
Deadhead
on Nov 6, 2006 at 10:21:40 am
The JL cooper MCS series gives a nice large TC display as well.
