Black ghosting when animating LiveType opacity
CUT
by
on Oct 24, 2006 at 3:32:44 pm
I am creating text animations in LiveType and rendering the movie files out with alpha channels to place in my time line. When I drop the movie file in my sequence, I see a faint ghost image of my text before the opacity change takes place from my animated movie. I have seen this happen before on files that had edge attributes like glows or shadows, but these files have no edge attributes. I am running FCP 5.1.1, LiveType 2.1, QT 7.1.3, Kona LH card, I am editing files into an Uncomp 10bit seq. I could use some help on this one if anyone has a work around or solution. Thanks!
Doug Ohlsen
CUT
The Lobby
Re: Black ghosting when animating LiveType opacity
on Nov 7, 2006 at 9:35:27 pm
you probably need to render from live type with a 'straight' alpha (it's probably defaulted to 'premultiplied'). it will look like crap until you key it over your footage but once it's keyed you shouldn't have the ringing or ghosting
