Kona LH + Panasonic 1200A
djsotrab
on Oct 17, 2006 at 10:51:43 pm
I have the Kona LH card and the Panasonic 1200A and am having difficulties laying my FCP HD sequence off to the deck using Edit to Tape.
However, the Print to Video function works fine.
Is this a limitation of the Deck?
-Josh
JeremyG
Re: Kona LH + Panasonic 1200A
on Oct 17, 2006 at 11:53:24 pm
In short, yes. That deck does not support rs-422 insert/assemble editing.
Jeremy
walter biscardi
on Oct 18, 2006 at 12:11:12 am
[djsotrab] "I have the Kona LH card and the Panasonic 1200A and am having difficulties laying my FCP HD sequence off to the deck using Edit to Tape."
You can ONLY Assemble Edit to this deck using Firewire as your Deck Control. It will NOT perform any edit using RS-422.
The new AJ-HD1400 will perform edits using RS-422 and can perform insert edits.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Food Network's "Good Eats"
HD Editorial for "Assignment Earth"
"I reject your reality and substitute my own!" - Adam Savage, Mythbusters
