Correct Kona 3.2 Easy Setup for HVX200?
fergush
on Oct 16, 2006 at 12:26:08 am
For DVCPRO HD material show at 720pN30 on an HVX200, what is the right Easy Setup to use?
Regards,
Fergus
fergush
Re: Correct Kona 3.2 Easy Setup for HVX200?
on Oct 16, 2006 at 12:31:19 am
sorry: "shot" at 720pN30
JeremyG
on Oct 16, 2006 at 2:18:11 am
I'm not sure if the Kona comes with a 30p easy setup so you should duplicate and modify a 720p24 setup so that the frame rate is 30p. Choose the 720p24 east setup then hit option-apple-q. You can then start to go through all the tabs starting with sequence preset. make sure to DUPLICATE the 24p setting first then rename and modify so everything reflects 30p (29.97). When you have made it through the tabs, click the summary tab again and make sure those newly created presets show up for each category (i.e. Sequence/Capture/ & device control presets has your new 30p settings) and then click the create easy setup button. Name it something memorable and away you go.
Jeremy
fergush
on Oct 16, 2006 at 4:27:04 am
Thanks, that worked perfectly. Seems odd that AJA don't include a 30p preset.
JeremyG
on Oct 18, 2006 at 12:50:21 am
I don't know, they don't include any anamorphic Sd presets either. It's just the way it goes.
Jeremy
