4K stereoscopic video with AJA KONA 3G card
Pierre Guilmin
on Jan 8, 2017 at 8:42:32 pm
Good evening,
I wish to use my AJA KONA 3G card to treat a double 4K stream coming from a stereoscopic camera. The left image is transmitted to the card through the SDI 1 input and the right one through the SDI 2 input.
I need to open those streams inside a Python program : I am using OpenCV to compute the depth map from both images, the final aim is to display the scene filmed by the camera in 3D on an auto-stereoscopic screen (a 3D-screen without 3D-glasses).
I need to be able to treat live each image in my program.
My problem is that I don't know how to access the so-called "Frame Buffer" I see in the software AJA Control Panel. Where can I find this stream on my computer ? (as an example, VLC is able to find a stream coming from the KONA 3G card when I click File->Open a Capture Device, I want to do the same in my program).
Thank you for your help,
PS : the AJA support doesn't respond me ...
