Ki Pro - LAN Data Transfer failures with El Capitain
Joel Porter
on Oct 27, 2015 at 5:23:29 pm
Hi everyone,
We have 3 Ki Pros recording 3 cameras recording to KiStor Drives.
The KiPros are also connected to a network.
At the end of a day, there are 2 files recorded on each drive (6 files in total) each file about 80-110gb.
Files are 1080i 59.94.
We use the network to transfer the files on to a large thunderbolt RAID drive connected to a 2013 Mac Pro running Yosemite (10.10). Pretty much flawless transfer each time.
I recently upgraded the Mac Pro to El Capitain, and now there is about a 50% failure rate when transferring files. It can be anywhere in the transfer process (some right away others almost complete then fail).
It also doesn't have to be as many or any multiple files, I tried transferring 1 or 2 files at a time and again, random failures happen.
This is the only thing that has changed in the transfer process. KiPros, Switch, Mac Hardware is all the same.
I also reinstalled El Capitain thinking it may have been a bad install but again, it's not consistent like it was on Yosemite.
Does anyone have any insight or suggestions as to why? I called AJA and they are also at a loss why this might be happening.
