Can the AJA be plugged into a computer while recording from a camera?
Brenna Perez
on Sep 9, 2013 at 3:31:24 am
Hey guys, trying to figure out a VTR solution. I need to have immediate reverse playback for something being shot on Alexa. As far as I see, no external recorders playback in reverse unless it's sped up. I need realtime backwards playback.
My best bet, as I see it, is running an external recorder that records every time the camera does. If it can be plugged into the computer simultaneously, via FireWire, that would be ideal, so I could bring each file onto the computer as it appeared, then run it backwards from there.
Would the AJA allow me to do this? I can't find any information online. If not, are there any other solutions you know of?
Many thanks!
Kenyon Blower
Re: Can the AJA be plugged into a computer while recording from a camera?
on Sep 9, 2013 at 5:23:59 am
You could use a remote control on the KiPro like a DNF. It should be able to control the KiPro & play -100% speed
Brenna Perez
on Sep 9, 2013 at 5:26:27 am
But will it allow me to play it at real speed in reverse?
