USB cable for KISTOR
Bob Tompkins
on Jul 23, 2013 at 1:59:18 pm
I received a KISTOR250USB drive from a client. I need to load it on my server but do not have the necessary cable to interface to USB from the drive. Can someone tell what cable I need and where I can find one? Thanks in advance for you help.
gary adcock
Re: USB cable for KISTOR
on Jul 23, 2013 at 2:27:56 pm
[Bob Tompkins] "I received a KISTOR250USB drive from a client."
Many of the original KiStor modules use only FW800 and all modules except for the 750 have both connections.
I believe that aja uses the Micro B connector on the device side, with a Standard A USB on the Other, and these should be available at any computer store.
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
Follow my blog at http://www.garyadcock.com
Or follow me on Twitter
@garyadcock
Bob Tompkins
on Jul 23, 2013 at 3:06:28 pm
Thank you so much for your swift response. I believe I own four of every cable except that one.
gary adcock
on Jul 23, 2013 at 3:17:55 pm
[Bob Tompkins] "Thank you so much for your swift response. I believe I own four of every cable except that one.
I only started seeing those cables last year, they are relatively new,
The issue I had is that I have not seen or worked with any of the USB3 KiStor modules or the New dock with both USB3 and TB so I had to dig around to find out which connector Aja went with.
gary adcock
Studio37
Chicago, IL
@garyadcock
Steve Eisen
on Jul 24, 2013 at 12:45:50 am
New KiStor drives have a USB 3 Micro B connection.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
Gunter Hemeleers
on Jul 24, 2013 at 8:56:36 am
it is a standard USB3 micro cable but if your host computer doesn't have USB3 connections you can also use a standard USB2 micro cable.
