Transfer Problem, Only Audio w/o Video
Scottie Tooley
on Feb 26, 2013 at 9:57:59 am
I searched the archive, but didn't see an answers to this question.
I am running Windows 7 64-bit, PPro CS5.5, Ki Pro Mini (with newest firmware), and a Panasonic AF-100.
If I record a scene to the Ki Pro Mini, when I transfer the resulting file from the device using Ethernet, I get a file that is audio only in PPro. I have it set to capture in ProRes, and I don't see any menu items I might have ticked in order to screw up the video. As for the menus in the AF-100, really the only option is to output over SDI, so I'm sure it is the Ki Pro Mini messing up.
I do not have a functional CF card reader, so I can't rule out if it is a transport issue (though that seems the most unlikely).
Does anyone have an idea as to what is happening?
Scott R Tooley
Scottie Tooley
Re: Transfer Problem, Only Audio w/o Video
on Feb 26, 2013 at 3:06:58 pm
Figured it out. When I upgraded our Dell Precision 690 to Windows 7, I never reinstalled Quicktime. This threw me for a loop at first, because I was under the impression that if Quicktime wasn't installed, you wouldn't be able to see or hear anything in a ProRes file.
But, apparently, you can still hear the audio but not play the video if Quicktime is missing.
