Canon C100 HDMI>Ki-Pro
dan luke
on Dec 13, 2012 at 12:15:03 am
I have a ki-pro mini. They suggest when recording at 24p or pf24 you configure the HDMI port for 3:2 pulldown and use the VFR setting on the Ki-Pro. Only problem is, I can't find any setting for the HDMI port other than rec command and timecode.
dan luke
Re: Canon C100 HDMI>Ki-Pro
on Dec 13, 2012 at 11:29:21 pm
Rudy from AJA support had the answer.
Menu -> 00:00 -> User Bit -> Output Mode -> Set to Pulldown
on the C100
