How could I format my Compact Flash cards leaving it as factory state?
Daniel Tundis
on Jun 1, 2012 at 7:29:17 pm
Whenever I plug my in one of my SanDisk Extreme 90MB/s Compact flash cards into my Aja Ki-Pro Mini it will only recognize my the card as unformatted media. When I try to format those cards I get stuck at the formatting window. I am looking for a driver or utility to restore my CF cards.
Notes: This is not happening with all of my CF cards, only a few. The only compact flash cards that are being effected by this were used in a sound devices were used in a Sound Devices Pix 240. I can see media that still remains on the cards when I use a reader on my MacBook.
Jeremy Garchow
Re: How could I format my Compact Flash cards leaving it as factory state?
on Jun 1, 2012 at 8:13:57 pm
Have you tried formatting on your Mac to HFS+ using disk utility, and then formatting in the KiPro?
Matt Mayer
on Jun 2, 2012 at 9:58:56 pm
PIX Recorders format the cards as UDF. IIRC, KiProMini formats as FAT32. Both formats are Mac/PC compatible.
You will need to reformat the cards in the recorder before using them in that recorder.
---Matt
Jeremy Garchow
on Jun 2, 2012 at 10:31:38 pm
KiPro is hfs+ actually.
I'd try using disk utility to format the card first, then use KiPro.
vince gaffney
on Jun 18, 2012 at 2:51:44 pm
I just went therough the same thing. Nikon formatted CF cards wouldn't re-format in KiPro mini. I formatted them in Disk Utility using Mac OS extended. (not journaled) They work fine now.
