Recording from Cable Box via HDMI or component.
Jeff Taylor
on Dec 28, 2011 at 1:55:34 am
I am attempting to record a signal from a comcast HD box. I have tried HDMI and component hookups with no luck. I did change the input to HDMI and component respectivley as well as the output. I have been unable to determine if it is even possible to record a cable signal onto the deck.
If anyone can give me some ideas and suggestions, it would be appriciated.
With regards,
Jeff Taylor
gary adcock
Re: Recording from Cable Box via HDMI or component.
on Dec 28, 2011 at 5:02:43 am
Sorry,
Aja adheres to the HDMI spec that includes digital copy protection, that is the reason you cannot get it to work.
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
http://blogs.creativecow.net/24640
Jeff Taylor
on Dec 28, 2011 at 4:59:32 pm
Thank you for your response. I thought that might be the case but wanted to make sure. Have a great day.
Rodrigo Allendes-Fernandez
on Dec 29, 2011 at 10:59:31 pm
Gary,
And what if I transform the signal passing through some converters? HDMI -> SDI, and (if no work) with another SDI -> HDMI converter?
Like I find a solution for Canon 5d Video Assist. Hdmi signal from camera, connected to a hdmi splitter (one for onboard monitoring; and the other for a HDMI-> SDI converter). Then I get a 480i signal, but in KiPro appears 525i. Otherwise, or without the splitter, signal jumps between Livemode and Reccording.
So, modifing the signal passing by several converters, will do eliminate the copy protection?
Video Assist Operator
gary adcock
on Jan 4, 2012 at 3:49:27 pm
[Rodrigo Allendes-Fernandez] "So, modifing the signal passing by several converters, will do eliminate the copy protection?"
there is no copy protection in an analog video signal.
gary adcock
Studio37
Chicago, IL
