Transferring content via Firewire
Daniel Postlethwaite
on Nov 1, 2011 at 11:25:50 am
Hi All,
I am wondering if it is possible to load clips onto the SSD via firewire, instead of 'recording' through the inputs.
The reason I ask is because I am using the kipro as a playback unit for a corporate event. I have a logo clip that needs to be looped. But when I 'record' the clip via HDSDI, I cannot be accurate enough to ensure a smooth loop. I would much prefer to load on the .mov file as it is perfect in terms of length for looping.
Any help, greatly appreciated.
Dan
Jeremy Garchow
Re: Transferring content via Firewire
on Nov 1, 2011 at 3:41:27 pm
Absolutely. It needs to be any flavor of ProRes movie at almost any standard frame rate with dual mono audio.
FYI, you should be ale to get frame accurate layoffs with a card that supports RS422, at least it works here. If doing any conversions (up/down/cross), set the KiPro to do them.
Jeremy
AJA Sales Department
on Nov 1, 2011 at 11:07:46 pm
As noted, any of the Apple ProRes 422 file types may be played back on the Ki Pro. In addition to the codec, the frame size must be a broadcast or digital cinema rate:
720p 23.98
720p 25
720p 29.97
1080PsF 23.98
1080PsF 24
1080i 25
1080i 29.97
Also, the Ki Pro requires the use of 24-bit 48kHz audio in dual mono or stereo. Many programs render to 16-bit by default.
If you have additional questions, feel free to contact AJA Technical Support.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
gary adcock
on Nov 2, 2011 at 1:30:03 am
Really?
720p 23.98 is a non -standard playback format and since the KiPro does not have the ability to add or remove pulldown, how is it possible to playback this frame rate as anything other than a conversion to 1080 23.98?
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
http://blogs.creativecow.net/24640
on Nov 2, 2011 at 7:22:08 am
Thanks for the replies!
