XLR 4 pin power conector with excesive heat.
Rodrigo Allendes-Fernandez
on Sep 26, 2011 at 6:01:27 pm
The summer is comming in this part of the planet, and I had noticed that the XLR 4 pin conector of the KiPro (metalic part) has a intense heat. If you touch it, maybe you'll feel a burning sensation.
Is this normal behavior?
Best Regrads
Video Assist Operator
Joe Barta IV
Re: XLR 4 pin power conector with excesive heat.
on Sep 27, 2011 at 2:56:16 pm
Mine gets hot, but it has never effected performance. The exhaust port for the cooling fan is right there where the 4-pin connector attaches, it does get pretty warm. The entire unit gets hot when it s recording/processing. Just do your best to keep it out of direct sun and don't block the cooling vents on either side.
Bars & Tone
SALUTE!
