Alexa framerates and Ki Pro
Rodrigo Allendes-Fernandez
on Aug 23, 2011 at 10:26:18 pm
Does Ki Pro support 3G SL (single link) to match all framerates from Alexa's Rec Out?
If Alexa is shooting at 40fps or 60fps, and Ki Pro only supports 1.5G SL (30fps max.), how can I emulate those frames lacking?
Is it comming an update or firmware release to reach more than 30fps at 1080p? I mean 3G SL support.
It would be great if we could playback those 60fps at, e.g. 24fps, 30fps, etc. (SlowMode), with a option on the config or media menu.
Video Assist Operator
AJA Sales Department
Re: Alexa framerates and Ki Pro
on Aug 23, 2011 at 10:44:37 pm
The Ki Pro is a single link 1.485Gbps device. It supports the following formats and frame rates as of version 2.0 firmware:
525i 29.97
625i 25
720p 23.98 (24) via the VFR selection from a 720p 59.94 signal
720p 25 via the VFR selection from a 720p 50 signal
720p 29.97 (30) via the VFR selection from a 720p 59.94 signal
720p 50
720p 59.94
1080i 25
1080i 29.97
1080p 23.98
1080p 24
1080p 25
1080p 29.97
1080PsF 23.98
1080PsF 24
1080PsF 25 via the PsF selection
1080PsF 29.97 via the PsF selection
720p 60 and 1080i 30 formats will be added to the Ki Pro with an upcoming firmware update in order to match the capabilities of the Ki Pro Mini product.
If you have questions about AJA products, don't hesitate to contact AJA Technical Support via phone or email for assistance.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
