Ki pro not reading input
Lynn Cual
on Jun 30, 2011 at 10:01:38 pm
Have a windows pc into a scan converter using the rgb setting. Ki Pro still not reading video input. Any suggestions?
AJA Sales Department
Re: Ki pro not reading input
on Jun 30, 2011 at 11:15:17 pm
You should try contacting AJA Technical Support via phone or email for assistance with this.
Please be aware that a scan converter may be outputting a format and frame rate that the Ki Pro does not understand natively. Additionally, you mention RGB; the full size Ki Pro product only supports component analog Y/Pb/Pr input, not RGB.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
james lowenthal
on Aug 18, 2011 at 7:17:50 pm
We just tried going out of a folsom presentation pro, component out, 1024 x 768 59.97hz directly into the component input on the kipro and can not get a signal. We take that same cable right into a monitor and it's good to go, so the cable is good and the output is there.
We've tried all of the different syncs on the input selection of the kipro component input to no avail.
Suggestions?
