Multi Camera Multi Ki Pros
Joe Christofori
on May 9, 2011 at 6:29:57 pm
Hey Guys
I am working on a multi camera show
I want to start a knowledge base here for this type of job
I am currently doing a 4 camera job as Ki Pro & Data Manager,
I have 3 Ki Pros & 1 Ki Pro Mini
I am using an ethernet hub or switcher to connect through a computer
I was using gang recording until I updated the firmware for the Mini today.
I restarted everything I can see the Mini in the browser but the Master just cant see the mini in gang record.
I can however use the mini as the Gang Master so I switched and made the Mini the master.
I do occasionally get dropped frame errors on the mini, thtas why I did the firmware update.
I will continue to add info as we go here.
Joe Christofori
Re: Multi Camera Multi Ki Pros
on May 9, 2011 at 7:19:12 pm
In the last hour,
we seem to be having issues with gang record,
settings dont seem to hold
Browser controls are lagging a bit
just restarted
Custom takes often dont take through browser either
& Yes I am clicking apply.
Jeremy Garchow
on May 9, 2011 at 8:13:38 pm
First, make sure all the wifi options are completely disabled.
What firmware are you running on everything?
AJA Sales Department
on May 9, 2011 at 8:18:14 pm
Joe,
You may want to contact AJA Technical Support for assistance with your particular configuration. They can be reached via phone or email between 9am and 5pm PST.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
Joe Christofori
on May 9, 2011 at 8:38:56 pm
ki pro--- 2.0.0125
mini is 2.5.0.8
Joe Christofori
on May 9, 2011 at 9:07:31 pm
disabled wifi 802.11
Jeremy Garchow
on May 9, 2011 at 9:53:29 pm
[Joe Christofori] "disabled wifi 802.11"
Meaning you just disabled it, or it was disabled?
Joe Christofori
on May 9, 2011 at 10:02:12 pm
I disabled it after you told me but it made no difference, D camera still doesnt show up in Gang list
I restarted all including ethernet switcher.
The recordings are fine its just the controller that is glitchy
I'm not trying to whine here I just want to put the info out there for you guys to know what happens with multi-camera situations
Jeremy Garchow
on May 9, 2011 at 10:01:58 pm
If you roll back the firmware on the Mini, does it show up? My hunch is yes.
Joe Christofori
on May 10, 2011 at 2:22:03 pm
Yeah Im sure it would and the new firmware isnt helping with dropped frames, so I may roll it back at lunch time
The call has also been made to change out this unit for a regular ki pro.
Joe Christofori
on May 10, 2011 at 1:12:36 pm
So what causes the dropped frames ?
it only happens in the first 10 seconds and only on the mini
Jeremy Garchow
on May 10, 2011 at 7:37:46 pm
[Joe Christofori] "So what causes the dropped frames ?"
Slow media?
Joe Christofori
on May 10, 2011 at 8:01:07 pm
Im using the sandisk 90mbs, which is in their pdf of approved media
sandisk extreme pro 64g and 32g
Jeremy Garchow
on May 10, 2011 at 8:25:22 pm
[Joe Christofori] "Im using the sandisk 90mbs, which is in their pdf of approved media
sandisk extreme pro 64g and 32g"
Got ya. Then you should be ok if everything is formatted/setup correctly. Perhaps you should contact tech support.
Jeremy
Joe Christofori
on May 11, 2011 at 8:14:59 pm
We took the Mini out of the mix and things are much better today
Regular & Mini just dont work together well..... yet.
im sure they will work it out.
Jeremy Garchow
on May 11, 2011 at 8:30:05 pm
[Joe Christofori] "We took the Mini out of the mix and things are much better today
im sure they will work it out."
I concur.
