PMW-F3 1080 25p problem
Matthew Day
on Apr 27, 2011 at 7:28:50 pm
Does anyone know how to record at 1080 25p from an F3. Camera is set correctly but the KI-Pro only displays 25i.
Check out our blog at http://www.claphamroadstudios.blogspot.com/
Jeremy Garchow
Re: PMW-F3 1080 25p problem
on Apr 27, 2011 at 8:29:20 pm
The KiPro is displaying the input it is given. Most likely the output of the F3 is psf, which means it is an interlaced stream (with progressive content in it). You will need to flag the files after you capture as p (or no field dominance). I haven't worked with the F3 yet so I am unsure of the output options for SDI. I am not sure if you can get a true p output in single link mode; most likely not, but crazier things have happened. It's not the Ki's fault.
Jeremy
AJA Sales Department
on Apr 28, 2011 at 1:13:51 am
The Ki Pro and Ki Pro Mini auto-detect incoming video format and frame rate. Having stated that, it should be noted that 1080PsF 25 and 1080i 25 appear the same "over-the-wire" with HD-SDI signals. The solution, if the source video is 1080PsF 25, and a 1080 progressive recording with no field dominance is desired, is to enter the CONFIG menu parameter 1.1 Record Type and select "PsF" from the list. This will produce a recording without field dominance (otherwise, if "Normal" was selected for Record Type, a file with Upper Field dominance, would be produced).
If you need additional information on this setting, you can refer to the Ki Pro operation manual for more details or contact AJA Technical Support via phone or email for additional assistance.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
Jeremy Garchow
on Apr 28, 2011 at 2:33:27 pm
Duh. Of course! Normal to PsF. If you have already recorded material that was flagged as i, you can use JES Extensifier to change the field dom metadata flag.
Jeremy
Jeremy Garchow
on Apr 28, 2011 at 3:23:51 pm
Like this:
Matthew Day
on Apr 28, 2011 at 3:48:43 pm
Many thanks!
