Pal to NTSC
Leonardo De Mai
Pal to NTSC
on Apr 8, 2011 at 11:41:33 pm
Hello everybody,
do you know if it is possible to convert directly from a SD signal (SDI) 720X576 PAL to NTSC ?
I just have production in Korea and I record in PAL system, but I have to produce in the same time a signal for local broadcaster.
Thank you for you help
Leonardo De Mai
Jeremy Garchow
Re: Pal to NTSC
on Apr 11, 2011 at 2:35:55 pm
The KiPro does not so standards conversion unfortunately. For that, you will need a dedicated converter.
Jeremy
Leonardo De Mai
Re: Pal to NTSC
on Apr 11, 2011 at 8:02:24 pm
OK thank you in fact I have try several option without result .
Thank
Leonardo
