File/Clip properties
Craig Alan
on Mar 26, 2011 at 5:32:18 pm
Clip properties/render time question
Canon hv40 HDV tapes captured/copied on
Ki pro to apple pro res 422 imported to FCP dragged to timeline set to ‘match clip’.
OSX 10.5.8; MacBookPro4,1 Intel Core 2 Duo 2.5 GHz
FCP 6.0.6
My problems began when I felt that all renders were taking too long.
When I look at clip properties in browser
I see
Vid rate 29.97 fps
FRAME Size: 1920 x 1080
Apple pro res 422
Pixel aspect: square
Field dominance: upper (odd)
The image looks fine but when I check clips from previous projects captured to apple pro res 422 in fcp directly the
Frame size is 1440 x 1080
and
pixel aspect is (HD) 1440x1080
Did I choose the wrong setting on the ki pro when I captured the HDV tapes on the Ki Pro?
Does it matter at this point?
The image looks fine to my eyes.
Would these properties account for the long renders?
If I need to recapture tapes, what setting should I chose on the Ki Pro?
; Camcorders: Sony Z7U, Canon HV30/40, Sony vx2000/PD170; FCP certified; write professionally for a variety of media; teach video production in L.A.
AJA Sales Department
Re: File/Clip properties
on Mar 26, 2011 at 7:57:32 pm
This sounds like your Sequence Settings are not set to match your clip properties; Ki Pro only produces full raster video so it would not produce 1440x1080 thin raster, but 1920x1080. Set your sequence to match your clips to resolve the rendering.
If you need further assistance, contact AJA Technical Support via phone or email Monday through Friday, PST.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
Craig Alan
on Mar 26, 2011 at 9:41:11 pm
Well I'm glad that I didn't mess up the Ki Pro capture.
Are square pixels correct?
I think my clips and sequence setting match. Here's the properties:
on Mar 28, 2011 at 4:35:13 pm
Yes, square pixels is correct for full raster HD material. There appears to be a mismatch between your clip and sequence audio properties. You may want to contact AJA Technical Support if you need assistance with your Final Cut Pro settings.
AJA Video Systems
(800) 251-4224 US
sales@aja.com
