720 24p
dan luke
720 24p
on Mar 26, 2011 at 5:17:44 am
shooting at 24p kpm clips are recording at 59.94. In the FC bin all the digitized tape is 23.98 but kpm clips are indeed 59,94
AJA Sales Department
Re: 720 24p
on Mar 26, 2011 at 7:28:30 am
To record a frame rate such as 23.98 fps from within 59.94 fps, VFR should be selected for the Record Type. If Normal, as opposed to VFR is selected, the Ki Pro Mini will produce the standard 59.94 fps. You can determine if the Ki Pro Mini is actually seeing 23.98 (24) by entering STATUS.
If you need further assistance, contact AJA Technical Support via phone or email Monday through Friday, PST.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
dan luke
Re: 720 24p
on Mar 27, 2011 at 9:25:48 pm
Well that worked. The 2 things that confused me were;
1) the note on page 35 of the manual which seemed to imply (at first glance) that 23.98 would be treated as PsF no matter what the record type setting was and
2) the status display which shows the top line (video) as 720 59.94
and the second line (audio) as 720 VFR
But as I said it all imports just fine thank-you very much.
-dan
James Parker
Re: 720 24p
on Aug 14, 2012 at 6:06:12 am
That's because your JVC is actually shooting at 59.94 fps but is using a 2:3 pull down to achieve the look.
We do the same thing with our 250's but leave the frame rate capture at 59.94 and all works well.
Jeremy Garchow
Re: 720 24p
on Mar 26, 2011 at 4:00:09 pm
What camera?
dan luke
Re: 720 24p
on Mar 27, 2011 at 4:21:27 am
jvc 250U
Jeremy Garchow
Re: 720 24p
on Mar 27, 2011 at 2:44:20 pm
I am not familiar with that camea but In addition to what Aja said ( kipro in VFR mode) double check and make sure that the userbits are in fact turned on set to tcg mode. On some Panasonic models, this is not turned on by default and you have to physically turn this feature on via the menus. Perhaps it's the same for JVCs.
Jeremy
Greg Kendrick
Re: 720 24p
on May 2, 2011 at 9:08:59 pm
Jeremy,
Thank you so much for your time answering my KP technical questions offline. I really appreciate your expertise!
