Red lines down side of clips
Jason Tower
on Mar 15, 2011 at 2:11:14 pm
We received some SD Ki Pro-recorded clips from an event video company that are all displaying vibrating red lines down the right side. Can anyone identify what may have caused these lines? Unfortunately, I don't know what camera was used to shoot this or what input was used on the Ki Pro, but I'm suspecting that it might be composite.
Below is the link to download a short 9MB ProRes clip that we received. This is a clip straight from the Ki Pro with no further compression.
https://rcpt.yousendit.com/1068754019/dbd1cb07295f4b89395ef44f4cb12582
Any assistance with this would be greatly appreciated!
Jason W. Tower
Fiddler Films
http://www.fiddlerfilms.com
AJA Sales Department
Re: Red lines down side of clips
on Mar 15, 2011 at 5:49:38 pm
Jason,
It would seem that there may have been an issue with an analog source that was feeding the Ki Pro. The Ki Pro accepts component, but not composite. So it's possible that there was some issue with the red portion of the component signal.
If the video signal that fed the Ki Pro had some issue, then there isn't much that can be done to resolve the issue once the QuickTime files have been produced.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
Jason Tower
on Mar 17, 2011 at 1:30:10 pm
Thanks so much for your quick response to my question! I figured it was most likely an issue with the signal that was being fed to the Ki Pro. In addition to the red lines, we also had to deal with a lot of graininess in the image that was caused by them using a camera that had poor low-light capabilities with the gain cranked up.
I knew that the Ki Pro wouldn't add that to the image!
Jason W. Tower
Fiddler Films
