format
Larry Watts
format
on Feb 23, 2011 at 4:07:55 pm
I'm confused about the standard def SDI signal path I get with our system starting with our JVC 250 U cameras into our AJA KIPros (3 isos) into our mixer and into a Final Cut Capture.
Our JVC cameras say in the manual they record 480/60i, yet the Kipros read the SDI signal as 525i and it records a 720x486 anamorphic file.
My problem is that the 4th camera records to a hard drive recorder at 720x480 file (DVCPro) and Final Cut will not create a multiclip with the 4th camera file without those extra 6 lines of resolution.
So is there a way to render the 720x480 file into a 720x486 file using compressor or some other method
so I can multiclip them?
Larry
Jeremy Garchow
Re: format
on Feb 24, 2011 at 9:35:34 pm
[Larry Watts] "So is there a way to render the 720x480 file into a 720x486 file using compressor or some other method
so I can multiclip them?"
Sure. Use the advanced format conversion options in compressor. All things must match in multi-clips. Format, frame size, frame rate, codec, etc.
