Cross conversion question(s)
David Smith
on Jan 31, 2011 at 2:04:38 am
Hello all,
I'm trying to cross convert a 720p 59.94 signal to 1080i upon input into a Ki Pro. When I set the input conversion to 1080 it gives me an Invalid Selection warning.
The GUI status window shows the Input at 720 59.94, but Record Format reads No Input.
Setting inconvert back to none and all is well, albeit at 720.
I'm sure I'm setting something wrong. Your help would be appreciated.
David
(Just to date myself... I think that's an HL-35 on my shoulder)
AJA Sales Department
Re: Cross conversion question(s)
on Jan 31, 2011 at 6:32:25 pm
David,
The "Invalid Selection" warning prompt would seem to indicate that you have a setting configured incorrectly for the conversion operation. An easy solution might be to enter the CONFIG menu and navigate to menu parameter 99.0 Factory Reset and perform a factory reset; this should clear out any mis-set parameters. Then re-enter the CONFIG parameter 1.4 In Convert and set it according to your desired format (in your case, HD 1080).
If this doesn't solve your issue, or you need further assistance, don't hesitate to contact AJA Technical Support.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
David Smith
on Feb 1, 2011 at 1:16:54 am
Thank you, I'll give that a try and will post the results.
Best,
David
David Smith
on Feb 2, 2011 at 4:18:11 pm
A factory reset did indeed resolve the issue. Thank you very much for your quick response.
Best,
David
Jeremy Garchow
on Jan 31, 2011 at 6:45:52 pm
Is the out convert set as well?
Is the recording type set to normal?
Oops, didn't see AJAs response at first.
Sorry!
Jeremy
David Smith
on Feb 1, 2011 at 1:22:50 am
I'm happy to get your input anytime Jeremy.
You know the output may well have been set.... I will test that before resetting to factory defaults just for fun.
Best,
David
David Smith
on Feb 2, 2011 at 4:20:17 pm
I tried it both ways, with output conversion on and off, and it made no difference. The factory reset AJA support recommended did clear up the issue and all is well both on output and input cross conversions.
David
