KiPro Not Recording 1080/24P
Doug Broomfield
on Jan 23, 2011 at 7:23:46 pm
I am using the Sony EX-3 camera. I have the camera's format set to HQ 1080/24p. Going HD-SDI out to the KiPro. I have the KiPro set to "Normal" for Record Type. Yet KiPro recoding shows it is 1080i 29.97 Any thoughts on why the KiPro is not showing the recording as 1080psf 23.98?
Daniel Doherty
Re: KiPro Not Recording 1080/24P
on Jan 23, 2011 at 10:49:56 pm
You have to go into the menu in the EX3 and find Genlock. In Genlock change the setting to 24p. That should do it if it's the EX3 that is not outputting the correct fram rate.
Doug Broomfield
on Jan 23, 2011 at 11:05:07 pm
Perfect Daniel. Solved the issue. Thank you do much for your quick response!
- Doug
