can´t gang recording
jose hipaucha
on Jan 4, 2011 at 6:05:49 pm
Hi everybody.
We have a pair of kipros with2.0 firmware and want to record the same video on both decks, for backup pourposes. Until now we can´t gang them. Have the right settings on the lan , the IPs, the gateway, but in the browser in the gang view button, never refresh, and never shows a recorder as configurable. I tried flashing the firmware and doing factory reset (usually works with other problems).
Help!!!!
thanks
Marc Colemont
Re: can´t gang recording
on Jan 4, 2011 at 6:58:59 pm
First try to 'ping' the IP adresses from a computer.
If they respond and still no gang recording settings appear.
Once and a while I have the same issue. Setting fixed IP settings didn't really help. Starting up all devices again fixes it for me.
Jeremy Garchow
on Jan 4, 2011 at 7:06:58 pm
Can you control both of them individually? Meaning, is your network "seeing" both KiPros?
jose hipaucha
on Jan 4, 2011 at 7:31:24 pm
yes, my net have 192.168.0.1 the pc 192.168.0.2 kipro 1 and 192.168.0.3 the kipro 2. Same gateway on 3 and a 3com 8ports ethernet hub betwen them.I can navigate over kipros menu via web browser, but the gang doesnt work!
thanks.
Marc Colemont
on Jan 4, 2011 at 7:35:44 pm
In my case I could control all 4 of them through the webpages. But I suspect the AJA protocol which detects the units for gang recording fails to detect ones and a while. I made a video of it which I wil send to AJA support.
Jeremy Garchow
on Jan 4, 2011 at 7:49:20 pm
[Marc Colemont] "I made a video of it which I wil send to AJA support."
Did you record it on a Ki Pro ;)
Jeremy
Marc Colemont
on Jan 4, 2011 at 8:35:07 pm
In fact yes I did :-)
