KiPro Mini how many channels of audio can it record
Brad Bussé
on Jan 3, 2011 at 11:54:51 pm
I'm considering a KiPro mini for use with recording the HD-SDI output of an AF100. Can the KiPro Mini simultaneously record all of the audio channels being sent out of the AF100 over the SDI, as well as the 2 XLR inputs on the KiPro Mini unit itself?
Jeremy Garchow
Re: KiPro Mini how many channels of audio can it record
on Jan 4, 2011 at 12:22:11 am
If the mini is anything like the big Ki Pro, you can only recored wither digital or analog audio, and not both. I am sure the mini will handle the 2-4 audio channels that the af100 will send.
According to the specs, it will record 8 channels embedded:
http://www.aja.com/products/kipro/ki-pro-mini/ki-pro-mini-specs.php
Jeremy
Marc Colemont
on Jan 4, 2011 at 7:01:32 pm
But it wil not record both. It's either the embeded SDI audio or the XLR's
Jeremy Garchow
on Jan 4, 2011 at 7:05:05 pm
[Jeremy Garchow] "If the mini is anything like the big Ki Pro, you can only recored wither digital or analog audio, and not both."
Yeah, sorry about that typo, should have been:
If the mini is anything like the big Ki Pro, you can only record either digital or analog audio, but not both.
Jeremy
