upgrade firmware 2.0?
Kim Rowley
on Dec 9, 2010 at 8:42:57 am
Just purchased Ki-Pro to record conferences through 2 different vision mixers. I have done this for 4 jobs to date (tried both component and SDI SD settings) and so far so good. The thread about the Ki-Pro stopping a few threads back spooked me and though personally I've had no trouble I am afraid to upgrade the firmware to 2.0. Should I be? Part of me says to leave well enough alone... Can somebody play Daddy and tell me it will be OK?
Dual 3 GHz Dual Core Intel, 4GB RAM, ATI Radeon X1900, Xserve RAID, AJA IO, 2 20" Cinema Display, FCP Studio 2 (6.0.6), OS X10.4.11
Jeremy Garchow
Re: upgrade firmware 2.0?
on Dec 9, 2010 at 3:38:42 pm
The KiPro works the same in that regard in v1 or v2. If it doesn't like the signal, it stops.
So, you'll be ok, just send a robust signal.
Kim Rowley
on Dec 9, 2010 at 6:45:32 pm
Thanks Jeremy. I thought so. It's just nice to hear it said. All the best
Marc Colemont
on Dec 13, 2010 at 1:23:33 pm
From a AJA tech support guy I also got the reply that the version 2.0 is a bit more forgiving for the signal input then version 1.1.
