Can the KiPro be used as a TC accurate playout device?
Pasquale Tropea
on Dec 7, 2010 at 12:14:29 am
Is it possible to use the KiPro as a playout device. Here's the scenario we currently playout our final online ProResHQ sequences to HDCAM SR via the Kona 3, but sometimes, due to numerous factors these playouts suffer 'dropped frames' and require a fresh start or an assemble edit, regardless it's painful and wastes lots of precious time
Can the KiPro be used as a playout device? We'd copy the final exported ProResHQ to the HDD. Can you lock TC together with an SR deck? Can it punch in and be frame accurate?
Pasquale
Jeremy Garchow
Re: Can the KiPro be used as a TC accurate playout device?
on Dec 7, 2010 at 4:41:27 pm
[Pasquale Tropea] "Can the KiPro be used as a playout device?"
Sure, but it'd have to be a crash record to the SR in single link 422. You can send LTC out to LTC in of SR.
[Pasquale Tropea] "Can it punch in and be frame accurate?"
As in insert edit? No. It would be, start the KiPro playback, hit record on the SR set to steal external ltc. I don't know how interesting that is to you, but the KiPro won't control the SR deck via rs422 if that's what you're asking.
Jeremy
Pasquale Tropea
on Dec 9, 2010 at 7:11:42 pm
Ideally the KiPro controls the SR Deck and synced playback/record occur. i understand that you can crash record but as long as the LTC is frame accurate, i.e. program start is at exactly 10:00:00:00
does AJA envisage creating a simple web GUI that could initiate the control of the SR Deck. The KiPro has an ether port with RS422 and a simple laptop could be used to layoff frame accurate playouts
/pasquale
Pasquale Tropea
Production Workflow Consultant
BBC Media Center - White City
Production Village - MC3 B1
Support Partners (UK) Limited
Shepherds Building F2
Rockley Road
London W14 0DA
UK Mobile: +44 7525 123 473
Tel UK DDI: +44 208 008 4921
Tel UK Main: +44 207 043 8206
Tel UK Fax: +44 207 043 8205
http://www.support-partners.com
pasquale.tropea@support-partners.com
Jeremy Garchow
on Dec 10, 2010 at 5:09:40 pm
[Pasquale Tropea] "Ideally the KiPro controls the SR Deck and synced playback/record occur."
It won't do that currently. Not sure if it ever will.
John Heagy
on Dec 11, 2010 at 4:33:23 am
Correct, the KiPro will not control, but the SR deck can. The SR deck can control the KiPro via 422 and accurately edit to it's self. There are many SR models. I don't know if all of them have this feature.
John Heagy
Pasquale Tropea
on Dec 21, 2010 at 10:25:51 pm
We've got 2 SRW5800s... where can i find more info on the RS422 control abilities of the sony decks?
thanks,
pasquale
Pasquale Tropea
Rockley Road
London W14 0DA
Pat McGillen
on Jan 2, 2011 at 5:00:12 am
As far as a playout machine, I currently use multiple KiPro's controlled via RS422 by Showplay software for multi- screen and edge blend content with Barco Encore systems, as well as for time-synced playout for symphony conductors timing marks video to keep in sync with movie content.
