Playback-Audio not in Sync
Tony Pasquale
on Nov 4, 2010 at 1:20:59 am
This is regarding using the Ki pro as a playback device only. Audio does not sync up or stutters when a video starts. Happens sporadically and it isn't a smooth playback. Anyone had an issue with this?
Jeremy Garchow
Re: Playback-Audio not in Sync
on Nov 4, 2010 at 2:47:53 am
[Tony Pasquale] "Anyone had an issue with this?"
What is the source of the video? Is this something you exported from an NLE? Please give a bit more info on how the file got on the Ki.
Jeremy
Tony Pasquale
on Nov 4, 2010 at 2:51:28 am
Sure. File was exported in FC as a ProRes with a dual mono 48khz 24 bit audio track. It was a final piece. File was then placed on the media drive.
Jeremy Garchow
on Nov 4, 2010 at 3:30:10 am
And how are you monitoring? What format/frame rate? Give me the whole picture.
What firmware?
Tony Pasquale
on Nov 10, 2010 at 4:48:33 pm
Firmware is 2.0 (the latest form AJA site) monitoring through both headphones as well as through a meyer system, via XLR to a DM1000 board. Format is ProRes frame rate 29.97. These are pieces that we have produced and are using the box as a playback engine.
Jeremy Garchow
on Nov 10, 2010 at 5:25:53 pm
You have reformatted the hard drive since installing the v2.0 software, right?
If yes, perhaps it's time to call AJA.
