FCP ProRess clips audio distorted
Marc Colemont
on Oct 12, 2010 at 10:33:31 am
I had trouble playing files with sound created in FCP which to be played properly by the Ki Pro.
In FCP in Apple ProRess defaults, the audio gives a hiss, when you play these files in the Ki Pro.
Files created for the Ki Pro as two seperate tracks of Mono:
24-bit Integer (Little Endian), Mono, 48,000 kHz do work.
Regards,
Marc Colemont
Jeremy Garchow
Re: FCP ProRess clips audio distorted
on Oct 12, 2010 at 12:12:24 pm
As you found out, the audio needs to be dual mono to be played back by the Ki. You are correct.
