Advice for COMPOSITE input
Bobby Abate
on Mar 9, 2010 at 1:00:36 pm
I want to take a composite signal from an old VHS camera and put it into the KI PRO DECK. I know the KI PRO only has component inputs. Is it really as simple as just plugging it into the Green Component - or do I have to use a Composite to Component converter?
If I do have to use a composite to component converter - what's the best (and the cheapest..)?
It seems a little pointless to convert a composite signal only to have the KI convert it again, but if it must be done - I'd like to know how to do it cheaply.
BB
-Bobby
Jeremy Garchow
Re: Advice for COMPOSITE input
on Mar 9, 2010 at 3:08:07 pm
Aja has a converter, or find a VHS deck w/component.
Alex Desrial
on Mar 11, 2010 at 4:40:51 pm
Hi JG,
I also want to try to use the old camera which has only composite output , convert it to component or SDI.. and record with Kipro.
Have you try the way..." How good is the quality we can get with this ? "
Can we still say we get 10 bit video with it ?
Thank you for the share JG
Best Regards
Alex
Alex Desrial
MediaIntegra - Jakarta
Jeremy Garchow
on Mar 11, 2010 at 7:25:41 pm
[Alex Desrial] "" How good is the quality we can get with this ? " "
It's still going to originate from a composite signal, even if you convert it to a higher bandwidth video signal.
Jeremy
Alex Desrial
on Mar 12, 2010 at 6:19:43 am
Hi JG,
Yes I know, it is still originate on composite.
But wondering if you have tried it and help get informed the quality as i never record from composite signal with Kipro yet .
Thanks Jeremy
Alex Desrial
gary adcock
on Mar 12, 2010 at 11:42:13 am
[Alex Desrial] "But wondering if you have tried it and help get informed the quality as i never record from composite signal with Kipro yet . "
Quality would depend on a number of factors, but my guess is
the comp signal is limited in resolution based on the camera but most likely less than 200 lines
your colorspace is also limited in Composite mode vs component.
http://en.wikipedia.org/wiki/Component_video#Component_versus_composite
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, IL
http://blogs.creativecow.net/24640
