traveling set-up
jeff cronenberg
traveling set-up
on Feb 19, 2010 at 12:28:16 pm
We plan to use Ki Pros this summer for a recurring multi-cam shoot. We will be working with 10 units, and we are looking into a traveling case. Actually more likely two cases, 5 and 5. While I know that there is no rack mount available currently, has anyone out there built a set-up with multiple units? Something that rolls in and you take the front and back covers off without having to pull all the units out of a case and set them on a table???
Thanks...
gary adcock
Re: traveling set-up
on Feb 19, 2010 at 2:48:41 pm
"While I know that there is no rack mount available currently, has anyone out there built a set-up with multiple units? "
I have designed a couple.
what's wrong with the mount points on the units themselves?
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, IL
http://blogs.creativecow.net/24640
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
jeff cronenberg
on Feb 19, 2010 at 2:52:58 pm
Great, would it be okay to contact you off forum to talk about this? you can email me at jmcbrg@gmail.com
thanks!
Jeff C
jeff cronenberg
on Feb 24, 2010 at 12:58:33 pm
Hopefully nothing wrong with that, I just don't have the actual units yet and haven't had the chance to look at one in "real life" so it's good to know there are ways to at least attach them to rack shelves... I was looking for input from someone that has already built one or to see if any companies were selling already built travel boxes.
How much physical space needs to be there between units to easily change out drives? and how much heat do the units generate, in other words how much air space should there be between units?
thanks; jeff c.
Michael Craven
on Feb 24, 2010 at 3:04:33 pm
[jeff cronenberg] "While I know that there is no rack mount available currently, has anyone out there built a set-up with multiple units?"
I've not seen these in person, but they might work for you.
http://www.markertek.com/Racks-Cases/Equipment-Rackmounts/Connectronics/CTX...
