Using KiPro to record DVD
Michael Moser
on Jan 28, 2010 at 7:38:48 pm
Is there any reason why the KiPro can't be used to convert the component or HDMI output of a non-restricted DVD from the component and/or HDMI output of a DVD player?
Michael Moser
gary adcock
Re: Using KiPro to record DVD
on Jan 28, 2010 at 7:51:34 pm
[Michael Moser] "Is there any reason why the KiPro can't be used to convert the component or HDMI output of a non-restricted DVD from the component and/or HDMI output of a DVD player? "
Recording of video from most consumer DVD players over HDMI is restricted by HDCP and the DRM security protocols- it is hard coded in the device and will not allow any discs to be recorded at all.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, IL
http://blogs.creativecow.net/garyadcock
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Michael Moser
on Jan 28, 2010 at 8:01:59 pm
Have they also hard-coded this into component output of consumer DVD players?
As there is no restriction on the disk, I thought there would be no problem.
I'm trying to see if the up-convert I get is better than the software based system I usually use.
I have an old Pioneer industrial DVD player which I'll try this with also.
-Mike
gary adcock
on Jan 28, 2010 at 9:28:24 pm
[Michael Moser] "Have they also hard-coded this into component output of consumer DVD players? "
Yes.the HDCP security is hard coded in the HDMI protocol.
It is one of the specs required when you license the HDMI connectors and technology.
gary adcock
Studio37
Chicago, IL
Michael Moser
on Jan 28, 2010 at 9:39:11 pm
Yes, I understand the security is on the HDMI, but what about the three wire component output of the consumer units.
Do they have a way of securing that as well?
Jeremy Garchow
on Jan 29, 2010 at 4:28:27 pm
[Michael Moser] "but what about the three wire component output of the consumer units.
Do they have a way of securing that as well?"
If your DVD doesn't have copy protection, you should be just fine. If not, you will have to go through a frame sync.
Jeremy
Michael Moser
on Jan 29, 2010 at 10:59:38 pm
It hasn't worked coming out of the component ports...I'll try a frame synch and report back.
-m
