Drive connection to Mac
David Roche
on Jan 25, 2010 at 9:09:43 pm
How are you connecting the removable drive from your Ki to your MacPro? We're using the supplied Firewire cable, but I'm figuring that we should be able to use eSATA for faster transfers. Are the SATA connectors on the drive standard connectors for external SATA drives?
Jeremy Garchow
Re: Drive connection to Mac
on Jan 25, 2010 at 10:23:10 pm
[David Roche] "Are the SATA connectors on the drive standard connectors for external SATA drives?"
Yeah, but you'd need power to supply to the drive. fw800 is more convenient, and not sure if it's all that much faster on a single spindle drive.
