Ki Pro playback options
Doug Ohlsen
on Jan 5, 2010 at 8:35:15 pm
I understand that the Ki Pro is primarily an acquisition device, but i have used it in a live event as a playback device, much like a ddr. My question to other users is this: Is there a way to set up a playback Que? If I have 4 to 8 files on the drive, can I get them to playback in a particular order and then loop? My hope is that I could then swap out one or two of the files in the que with time sensitive updates, without having to re-output all of the files.
Thank you for any insight that you can give
Doug Ohlsen
gary adcock
Re: Ki Pro playback options
on Jan 6, 2010 at 12:34:38 pm
[Doug Ohlsen] " My question to other users is this: Is there a way to set up a playback Que?"
the unit is designed to playback files in consecutive order based on the time the file was created.
there is no interface to playback in any other order which may be an issue for his workflow.
there is a Play All and Loop setting for playback, that will allow you to playback all files in a looping manner.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, IL
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
