BB/ Blackburst/ Sync/ Genlock, seamless playback, edit
Chris Thomsen
on May 14, 2009 at 7:59:36 pm
i want to integrate the Aja KI Pro into an analog studio (component). Normally every device has to be synced. On the back of the Aja KI Pro i can`t see any BB or Genlock inputs.
Do i have to use a timebase-corrector in this case?
Is it possible to loop an specific file seamless?
Is it possible to divide/ truncate/ delete files by using the buttons on the front in stand-alone-mode?
Greetings C. Thomsen
Jeremy Garchow
Re: BB/ Blackburst/ Sync/ Genlock, seamless playback, edit
on May 14, 2009 at 8:56:50 pm
[Chris Thomsen] "Do i have to use a timebase-corrector in this case? "
No, you can tell the Ki to sync over Y of the incoming component video.
[Chris Thomsen] "Is it possible to loop an specific file seamless? "
Yes, looping is seamless and there's a parameter that can be set to do so.
[Chris Thomsen] "Is it possible to divide/ truncate/ delete files by using the buttons on the front in stand-alone-mode? "
You can create a playlist of sorts to play files, but all editing will need to be done on an NLE.
Hope that helps,
Jeremy
Chris Thomsen
on May 15, 2009 at 5:51:03 am
Yes, thank you very much.
