New Products from AJA -- Record to ProRes in the Field!
Russell Lasson
on Apr 20, 2009 at 3:14:08 pm
So go check out AJA's new website.
http://www.aja.com
They've come out with some great new products. While I'll be picking up a couple of the new Kona LHi cards, I'm really excited to see how the new Ki Pro is going to change the industry. For the first time, you can actually upgrade your camera's codec to ProRes! 10-bit, full-raster, visually lossless, edit-friendly!
This is quite the achievement and opens up new possibilities regardless of which camera your using. This can change your workflow if you're using something as small as a Canon HV30 or as large as a Arri D-21 or RED ONE. Check it out and let's start hearing what you think!
-Russ
Russell Lasson
Universal Post
Ridgeline Digital Cinema Mastering
Salt Lake City, UT
James Disch
Re: New Products from AJA -- Record to ProRes in the Field!
on Apr 20, 2009 at 5:02:27 pm
Thanks Russell,
It seems like this can do everything the IO HD can do? Is that correct?
http://www.rapidlightproductions.com
