aja kona 3 firmware
Jan Klonowski
aja kona 3 firmware
on May 31, 2013 at 7:17:58 pm
hi guys,
iv got an used kona 3 but got some problems unsing avid and scratch, mazze from the assimilate mentioned firmware update. unfortunatly i cant find any updater for this, i use driver version 10.3.2 on windows machine my actual fw is
Hardware ID:
KONA 3 (0x10196500) S/N 00B21950 K3-Box Breakout Box
VideoProc Bit file:
2011/05/11 15:26:35 DownConvert
PCI Bit file:
2011/05/11 15:26:35
Driver Version:
10.3.5 build 25 64bit
can someone pls tell me if this is tha lattes firmware
kind
regards jan
Kevin Christopher
Re: aja kona 3 firmware
on Aug 20, 2013 at 5:01:57 pm
You have newer Firmware than I do, but older drivers. I run both mac and PC via boot camp. on the mac there is a firmware updating application. If memory serves me correctly on the PC side the driver loads the firmware on initialization. This is what allows AJA to upgrade the functionality of the card so easily.
Kevin
